Re: Super A Carb.
Posted by Gene-AL on February 13, 2006 at 19:35:46 from (72.147.64.140):
In Reply to: Super A Carb. posted by Joe Kelly on February 13, 2006 at 09:18:03:
Joe, If gas is leaking from the little screened hole in the bottom if the Carb air-inlet tube, it's supposed to do that when the float needle valve fails to seat and the float bowl gets too full (floods). If you need to run the tractor without doing anything further, try this: Just open the tank shut-off valve, briefly, to let some gas into the carb bowl (if needed), then shut the tank valve off untill you get the engine running, then open the tank valve. I've started my SA many times and driven out of the barn, forgetting to open the tank valve. If the needle leak is minor, the tractor will probably run just fine until you shut it off, then may flood and leak again if you fail to close the tank fuel shut-off valve again. It's possible that small bits of rust or trash are causing the float needle not to seat properly. I've never been a fan of "if it don't work exactly right, rip it all apart and rebuid or replace it". I'd rather find the exact cause of the problem and just fix that. If you run it a while, the problem could go away if the needle starts seating. If you rebuild/replace the carb, bits if trash coming from the tank could still have the same effect, all over again. If the needle valve is really bad or the float is stuck against the bowl, then the tractor would run rough, lope, smoke, and the engine would probably die flooded. The third carb brand was Carter, according to my original '51 SA owner's manuel. Caution, more than one type was used of each brand. Good luck...
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
