Re: 656 Loader tractor
Posted by chadd on February 14, 2006 at 04:41:54 from (155.92.30.227):
In Reply to: Re: 656 Loader tractor posted by Jonney M on February 13, 2006 at 15:57:05:
I don't have a list with the exact speeds, but I would imagine that the speeds would be pretty similar, maybe a little faster. If not having enough gears is a problem, get one with a T/A. That'll give you 10 forward speeds and 2 reverse. With the T/A on though, each gear is 10 or 20% slower than normal, so it may not be of help. We had a 656, but ours was a Hydro, so ours had infinite speeds within two ranges. Always thought that would have made a great loader tractor.
