Re: Whining noise in Super M live pump
Posted by RustyFarmall on February 14, 2006 at 12:19:01 from (199.120.81.205):
In Reply to: Re: Whining noise in Super M live pump posted by chadd on February 14, 2006 at 12:11:17:
Chadd, you are correct, HyTran will work just fine in the belly pump and then that tractor will be compatible with the rest of the machinery in use. My dads old H had JDD hydraulic oil in the belly pump because then it was compatible with the 3020 and 4020 Deere tractors. Those old lift-all systems really don't care what type of oil is in them.
