Re: H Brake Problem
Posted by kfox on February 16, 2006 at 04:46:03 from (63.18.165.228):
In Reply to: Re: H Brake Problem posted by 772TAS on February 15, 2006 at 21:44:10:
The brake adjuster is the connection between the brake pedel and the arm on the shaft coming out of the brake housing. My first experience with H brakes was on a 1941 model that had set for a long time. The shaft that operates the brake shoes was frozen in the side of the transmission housing and it took me most of a day to get the cover off, and most of the next day to get the shaft out of the brake cover. After i relined the brake shoes, I needed to adjust the brakes, and the the clevis that is on the end of the threaded shaft(that sticks out of the big spring) broke off of the threaded shaft like it was made out of glass. It appears to be spot welded on, so be careful when you try to turn it. Went to the boneyard and got a replacement and it fell off when I tried to turn it. ken
