340U Starting system Woes
Posted by DC-TX on February 17, 2006 at 08:36:01 from (207.69.137.27):
I have studied Bob's wiring diagrams and read every post, I think, about wiring. I just am rather dense about electrical systems.
-Problem: I can't keep the battery charged. It is a new battery, 2nd in several months due to my error. I surmise the unit is draining the battery when sitting, switch off and I likely need a diode(?) what ever that is, somewhere.
-System:
-Delco Remy alternator with batt connection and a 2 wire pigtail.
-Voltmeter, new, grounded from neg terminal per installation instructions.
Voltage regulator has been completely by-passed peradvice of a IH shop. I am told alternator has built in regulator.
-New coil with internal resistor.
-Voltmeter shows 12/13+ when running. After charging battery to get it started, voltmeter shows 14/16 until properly charged.
-How I have it wired: ( I am using proper gauge wires)
-From Alt: Pigtail #2 to Alt Batt Bolt.
Pigtail #1 not in use. I do not get a reading when I put a meter it.
-Alt Batt bolt to voltmeter on + side.
-From voltmeter on neg side:
-Grounded per above.
-Wire to starter post.
-Wire to ignition switch.
-Wire from ignition switch to push button starting switch.
-Wire from push button starting switch to starter solenoid.
I Hope this makes sense. I know someone out there can help me.
Thanks SO MUCH in advance-DC
