Re: Operating Temperature SuperH
Posted by BillyinStoughton on February 17, 2006 at 11:54:02 from (208.50.85.56):
In Reply to: Re: Operating Temperature SuperH posted by Andrew Z on February 17, 2006 at 09:20:42:
Nat 2 is right on the money with that. I will say one thing though, it is not that tough to get the shroud around the fan and get it into position on the radiator. I have a very late 52" H (389442 X1) that has the same pedestal and radiator as your Super, and with a moderate amount of patience and a little bit of massaging, you should be able to get that shroud in place in a manner of minutes. Be sure to turn the fan so as to allow you the most space as you put the shroud in place. If you are buying a shroud, be sure to get the four long through bolts that secure it in place. The correct bolts will save you some time in the final stages of assembly. I would recommend knocking the hood and grill off if you haven't already as it will speed things up and only requires five minutes to do.
Good luck!
Billy
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
