Re: Serial no and parts B250
Posted by David Sheridan on February 18, 2006 at 03:40:45 from (60.231.228.16):
In Reply to: Re: Serial no and parts B250 posted by MJ in the UK on February 18, 2006 at 03:09:43:
Thanks MJ for your quick reply. Wher do you get a copy of these serial no. registers? I wouldn't mind getting one. Also any sites, members or others that you could point me in the direction of would be appreciated. Very little info here down under.
My B250 has the steering rod either side as you rightly suggested. Would love to get a remanufatured/copy steering wheel to finish things off. I managed to get new guages , brake discs etc. Now apart from a paint job and re-chroming of badges I am complete.
Does yours have a verticle exhaust. Mine has a muffler at the rear but there is a hole in the hood for what looks to be a vertical exhaust but if one is fitted then how the hell do you tilt the hood to check everything?
Thanks again
David Down Under
