Re: Piston pin bushings
Posted by CRUSADER on February 18, 2006 at 12:36:10 from (61.34.58.162):
In Reply to: Re: Piston pin bushings posted by Kelly C on February 18, 2006 at 02:53:31:
Hello Kelly C,
I follow your posts very closely, but very seldom post at all to yours or others posts. To press the bushings out for a six cylinder engine and press new ones in takes about an hour (give or take) with an arbor press. However, to hone out the bushings to fit each pin correctly fit each pin and bushing for each rod on a hone/reamer can take a very long time. I know it seems like a lot of money, but it's not if you think about what time it takes to precision fit each pin to the bushing in the connecting rod. This is just my opinion, take it for what it's worth,
Jim
