Re: Stuck in gear
Posted by Hugh MacKay on February 18, 2006 at 18:34:15 from (209.226.247.14):
In Reply to: Stuck in gear posted by Tweeter on February 18, 2006 at 15:57:52:
Tweeter: I'd have thought we had this one well covered by now. It must come up at least once per week. Both you and Steven need to build up the bottom end of gear shift lever. If you look at the notches in those shift rails, your lever end should be just about the size of the notch in one rail. Build it up by welding then grind it to a rectangle, very slightly rounded on the corners. Tweeter, the problem you have right now is your tractor is in two gears at same time. The shift lever, being worn small slipped out of one rail notch before disengaging gear, then you put it in another gear. With the shift lever out you will notice each one of those rails have a forward, center and rear position. You can move them with a big screwdriver. All three rails must be in center position for neutral in transmission. You may find tractor is solidly locked in two gears. Two get it out you may have to tug either forward or backward on tractor. The best way to do this is an anchor vehicle and set of cable come alongs. You will have to play that one a bit, but it will come when presure is right. BUILD THE GEAR SHIFT LEVER UP, YOU MAY BUST GEARS THE NEXT TIME.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
