Re: Farmall M Starting problem
Posted by bgoathill on February 18, 2006 at 18:35:43 from (207.199.249.170):
In Reply to: Farmall M Starting problem posted by Ben Elder on February 18, 2006 at 18:27:50:
Make sure all of your connections are clean and tight. I have the same problem with my H about once a year.
