Re: tap for exhaust manifold
Posted by billde on February 19, 2006 at 07:40:37 from (66.249.53.208):
In Reply to: Re: tap for exhaust manifold posted by GordoSD on February 19, 2006 at 07:02:58:
If you cut 4 1/8 inch grooves with a cut off wheel perpendicular to the threads, to slightly below depth of the threads, this will give the rust&crud a place to go when reforming the old threads.
