Re: a,b,c waterpump
Posted by dave BN on February 19, 2006 at 16:35:53 from (152.163.100.65):
In Reply to: a,b,c waterpump posted by d masters on February 19, 2006 at 13:39:59:
My C does not have a water pump. I use my BN and my C pretty hard plowing and disking in hot weather and they do not get hot. I do rest them every hour or so and PTO work is probably harder than pull work. Still I don't think you should have a problem unless you are mowing very heavy stuff. Maybe a good flush and refill with 50-50 distilled water and Prestone (green) will help. Be sure to back flush the lower water line real good. If you install a water pump you may need a different radiator cap and I don't remember how the belt that drives the water pump is routed. Dave.
