Re: 1957 IH 350 Transmission is stuck
Posted by Dave in MN on February 19, 2006 at 16:52:27 from (204.221.132.37):
In Reply to: 1957 IH 350 Transmission is stuck posted by Matt Steele on February 19, 2006 at 16:47:51:
If the tractor has been outside with temp below freezing, you might have enough water in transmission to freeze it up.
