Re: Sleeve Puller?
Posted by El Toro on February 20, 2006 at 15:45:51 from (64.12.116.65):
In Reply to: Sleeve Puller? posted by kfox on February 20, 2006 at 14:39:29:
If the H has 3.375" pistons your puck should be
undercut to 3.355" so it will fit inside the sleeve. You need to check the overall block bore diameter and have the puck machined enough to clear the block bore. Probably somewhere around 3.550". The puck needs to have a 3/4" hole in the center of the puck so your allthread can be attached. Hal
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
