Re: Magneto vs. battery ignition
Posted by jossette on February 20, 2006 at 20:03:27 from (216.114.223.146):
In Reply to: Re: Magneto vs. battery ignition posted by EH in KS on February 20, 2006 at 19:58:21:
see if the battery has 3 cells or 6. if there are only three you should make it positive ground.
If there are 6 cells, there is probably a ballast (porcelin) resistor that is bad and will not let you start it.
