Re: Magneto vs. battery ignition
Posted by gene bender on February 21, 2006 at 02:05:46 from (66.43.221.211):
In Reply to: Magneto vs. battery ignition posted by EH in KS on February 20, 2006 at 19:44:53:
Should be 6v with positive ground with the + post of the coil going to the dist. To polorize the gen just touch the batt terminal of the regulator to the ARM term on the gen it should draw a small spark as you just momentary touch the two terminals with a piece of wire. My mag tractors cause no problems and the dist should be trouble free also.
