Re: H4 Magneto Distributor Gear Timing
Posted by gene bender on February 21, 2006 at 02:19:34 from (66.43.221.211):
In Reply to: H4 Magneto Distributor Gear Timing posted by Don Mountain on February 20, 2006 at 12:25:22:
Just line up the gears so when the impulse trips the rotor is lined up with the plug terminal on the cap.
