Re: How to find implement parts/components
Posted by El Toro on February 21, 2006 at 04:06:19 from (205.188.116.133):
In Reply to: How to find implement parts/components posted by Brewtus on February 20, 2006 at 20:25:00:
The Farmall A used 2 levers that are mounted on the tractor. One lever should have counter-balancing springs to aid in lifting the plow and probably other implements. The other lever was used to tilt the plow point. There should be brackets on the plow for connecting the plow to the tractor. Hal
