Re: Farmal A Starting
Posted by Randy Tillery on February 22, 2006 at 19:39:49 from (71.133.183.157):
In Reply to: Re: Farmal A Starting posted by JMB on February 22, 2006 at 19:33:54:
Cable is new and large enough for the six volt system. Sounds like next step is check the connection at the ground and other locations. I'll check the voltage while I'm at it. Randy
