Farmall Tractors Discussion Board
Re: Re: Re: Re: Super A compression and charging question.
Posted by twopop on January 09, 2000 at 16:11:46 from (208.237.247.195):
In Reply to: Re: Re: Re: Super A compression and charging question. posted by mk on January 09, 2000 at 15:11:17:
actually the compression i listed is probably a little on the high side for the super a depending on what the ratio is which can run from 6 to 1 on up to 8to 1 however if the comp.ratio is the same for an A as it is in a super then the psi would be the same. 8 to 1 comp. ratio would top out at 126 psi where a 6 to 1 would top out at around 90
Post A Followup
: Re: Re: Re: Re: Re: Super A compression and charging question.
