Re: Leaking hydraulics on Super A
Posted by CNKS on February 23, 2006 at 13:38:39 from (204.249.178.138):
In Reply to: Leaking hydraulics on Super A posted by Mark on February 22, 2006 at 16:36:21:
If the leak is external at the reservoir, and not the pump, you need a kit for that -- considerably more work. You might as well remove it, clean it, and use all the seals/gaskets in the kit. Rebuilding that unit will likely improve the performance of the raising and lowering also.
