656 ringear/starter problem solved
Posted by Yellott Canby on February 24, 2006 at 05:30:16 from (4.131.38.117):
Hello,
A couple weeks ago I was on here regarding a sticking starter on and a brand new ring gear on a Farmall 656. Just wanted to report that I found the problem. Turns out that the drive was the wrong one for the starter. Probably had been for years. In the end I had the rebuilder man order the exact drive for the casing # on the starter and that solved it. It was still a 9 tooth counter clockwise gear, but it was slightly longer. Probably could have gotten away with flipping the old flywheel after all. The new one didn't have a beveled tooth and could be used in either direction.
Sure thank you all for the help. I guess I learned to make sure to order the exact drive for the starter #, when ever there is a question. Thanks YC
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
