Re: CUB STARTER
Posted by Nat 2 on February 24, 2006 at 08:13:55 from (64.80.108.53):
In Reply to: Re: CUB STARTER posted by FLOPGUNS on February 23, 2006 at 19:19:41:
YOU DO NOT NEED A 12V STARTER THE 6V STARTER WILL WORK FINE JUST DONT CRANK AND CRANK AND CRANK AND CRANK IF THE ENGINE WONT START FIGURE OUT WHATS WRONG AND FIX IT IF THE STARTER IS WORKING DONT MESS WITH IT
