Re: valve adjustment
Posted by the tractor vet on February 24, 2006 at 15:43:23 from (64.179.117.165):
In Reply to: valve adjustment posted by famall lover on February 24, 2006 at 12:43:38:
The way i do it is to bring it up on #1 TDC and set it the bring #3 up on tdc and set it then to #4 and set it and and then #2 i leave the spark puls out and use a small flash lite to look in and see when it is on TDC ya have to sorta feel for TDC on each and i always go back over a couple times just to make sure
