Re: Farmal A Starting
Posted by MACE on February 24, 2006 at 18:57:00 from (66.23.230.13):
In Reply to: Farmal A Starting posted by Randy Tillery on February 22, 2006 at 19:21:50:
If you have:
all clean connections that are tight
suitable and recommended wiring size for 6 volts
a charged battery
a good clean starter
a properly wired and working charging system
your farmall A 6-volt starting system will work fine.
Take one of these away and you will start to have problems.
MACE
