Farmall Tractors Discussion Board
Re: Belt tension
Posted by The Red on January 09, 2000 at 22:21:15 from (12.75.197.222):
In Reply to: Belt tension posted by Jason Will on January 09, 2000 at 21:29:11:
If you are talking about the main fan belt, there is an adjustable flange on the water pump pulley. If you are talking about the generator belt, the adjustable flange is on the generator pulley.
Post A Followup
: Re: Re: Belt tension
