Re: Super M engine overhaul... disasterous? Cleara
Posted by Dave Slater on February 26, 2006 at 10:32:50 from (152.163.100.65):
In Reply to: Super M engine overhaul... disasterous? Clearance posted by Tim Malin on February 25, 2006 at 20:50:18:
You have some good advice,but im curious about some things in your post.Its not clear to me if new sleeves are being used or the sleeves that was in engine already.What about one cylinder needing bored .003 in your post,is this before sleeve is installed or after? If using new sleeves & pistons from a quality manufacture the bore in block should be checked before installing sleeves.If its within spec for the sleeve being used and sleeve is installed correct no other machine work should be needed.Will take some time
but a good machinest can remove studs.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
