Re: #!@*$# handcrank !
Posted by CNKS on February 26, 2006 at 16:57:09 from (204.249.178.138):
In Reply to: #!@*$# handcrank ! posted by Tom F on February 26, 2006 at 14:09:33:
I removed the upper bolster on my Super H and disassembled then put it back together. That was part of my restoration process, don't think I would have done it just for the crank. I cranked tractors for years as a kid on the farm -- never a problem, you just have to know what you are doing. I still do occasionally, as you can start a distributer equipped tractor with a "dead" battery, as long as it has enough left to produce a fair spark. With low batteries, most of the current goes to turn the starter. I would never give up a crank.
