Re: Farmall H Oil Pump
Posted by El Toro on February 27, 2006 at 14:48:39 from (152.163.100.65):
In Reply to: Farmall H Oil Pump posted by Andrew Z on February 27, 2006 at 13:38:46:
Did they install new cam bearings too? You need
.001" to .0015" clearance on the bearings this is how you get good oil pressure. The oil pump
housing may be worn and the gears too. I don't think there's replacement gears for the H pump. You may have to buy a good used pump. You need to disassemble and inspect. I would put a gauge on it that is divided in 10 psi increments so you know what you have. Here's a web site for salvage yards. Hal
PS: 16 pages of them.
http://www.epartdirect.com/index.php&t=fc&s=s
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
