Re: SD cowboy heading to florida.....
Posted by tobaccoman on February 28, 2006 at 04:24:33 from (199.147.53.245):
In Reply to: SD cowboy heading to florida..... posted by caseyc on February 27, 2006 at 12:57:03:
If you want to drive a little bit, there is an alternative to Disney. As luck would have it, a tractor show, gas engine, etc will be at Pioneer Park in Zolfo Springs Fl on Mar 1 thru Mar 5. Zolfo Springs is located on Hwy 17 south of Bartow Fl. It will probably take you a couple of hours from Orlando to get there. Do a google search using the words above for more info or give me a holler back.
Where "bouts in SD are you? We used to stay in Chamberlain while out there pheasant hunting.
