Re: Farmall M has no power
Posted by El Toro on February 28, 2006 at 05:29:25 from (205.188.116.133):
In Reply to: Re: Farmall M has no power posted by Andrew Okey on February 28, 2006 at 05:07:56:
Either method will work, but using No1 and No4
pistons at TDC on the compression stroke you can adjust 4 valves instead of 2. You can adjust them with the engine running too, but it's a little messy and hard to use a feeler gauge with everthing moving and trying to adjust the valves.
Hal
