Re: wisconsin quick fix pt.2
Posted by El Toro on February 28, 2006 at 08:19:39 from (205.188.116.133):
In Reply to: wisconsin quick fix pt.2 posted by all for school on February 28, 2006 at 07:41:02:
As long as the drain cock on the tank is above the carburetor a few inches, it should let the gas gravity flow to the carburetor. I would make sure you have a shutoff valve just in case
you need to shut off the gas. I would be careful
running that engine indoors due to carbon monxide
and any gas fumes in an inclosed area. Hal
