Re: Antifreeze in my Oil
Posted by Andrew Z on February 28, 2006 at 09:07:49 from (204.60.191.73):
In Reply to: Antifreeze in my Oil posted by Golddusttwin on February 28, 2006 at 08:52:16:
I would pull the head and check that gasket out. It could be that. It could be that you a have a crack in the head? However I had the same thing happen on my Allis B. The "O" rings on the bottom of the sleeves were all dried out and started leaking. When you pull the oil pan. Check to see if can see rust around the bottom of the sleeves. Its not really a hard fix but its kinda a pain.
Andrew
