1066- to IaGary etal
Posted by Michael Sheik on March 01, 2006 at 04:58:16 from (199.153.205.246):
Tightened up the 3 point control lever friction brake bolts last night and it took 1.5 turns at 1/4 increments to hold them in place. Works Good! Thanks
Tonight I tear apart the brakes on left side as very little assistance in turning. The outside housing removal procedure is evident as remove 6 bolts and pull off outer housing, remove disc, intermediate plate, brake adjuster assy, primary plate, piston insulator and piston. I am assuming that there will be no need to unbolt and remove brake piston housing from tractor unless I see oil leakage from the seal on bull shaft or o-ring on back side. Am I correct?
