Re: helical gear on top of steering post on M
Posted by Bob M on March 01, 2006 at 10:22:45 from (151.190.254.108):
In Reply to: helical gear on top of steering post on M posted by Henry Hiss on March 01, 2006 at 10:08:45:
Henry - If you haven't already, remove the lower bolster/front wheel assembly (flanged connection on the lower end of the upper pivot shaft). Then try the hammer thing again.
Reason: The bolster/wheels in place are a couple hundred pounds of mass absorbing most of the energy in your hammer hits. The hammer will be MUCH more effective when it's working only on the relatively upper light pivot shaft!
