1066 Left Brake - More info - T Vet
Posted by Michael Sheik on March 01, 2006 at 16:24:52 from (64.250.199.205):
Well, it is amazing what getting ticked off can do for a person. I twisted off and decided to pull the piston housing and good thing as I was a little scared of the seal and now can replace easily. Also was able to get piston out by doing as you had recommended. This way the seal and o-rings will be new and no worry. How much wear on plates can I tolerate? I have approx. 3/32 groove wear at present and suspect that new linings will not seat well into plates. Should I purchase new plates also?
I foung the adjuster pins after applying compressed air and cleaning outer housing. How did you say to adjust these prior to installation?
Any other suggestions or comments?
Thanks!!!
