Re: Weight of 1466
Posted by Randy in NE on March 02, 2006 at 04:18:57 from (204.124.192.90):
In Reply to: Weight of 1466 posted by 61-4010 on March 01, 2006 at 14:32:22:
I think that you will be in the 16-18,000 lb range. I know a farmer that has to drain the fluid out of the tires to get down to 15,500 for pulling. That leaves the cab and a couple of weights. He can pull it in the 18,000 lb class with cab, a couple of weigths and fluid in his 23.8x38s. Plan on the conservative side and plan on at least 18,000 or even better go for the 20,000 lb side of caution. It is better to err on the safe side.
