Re: 49 h
Posted by Janicholson on March 02, 2006 at 06:33:16 from (199.17.6.175):
In Reply to: 49 h posted by joel bouchard on March 02, 2006 at 05:06:14:
If your tractor is original, and equipped with a "belly pump" (located in the bottom of the transmission tunnel called a torque tube. It has one control rod on the right side of the operating platform with a bent ring loop handle. This is a single acting (one way) hydraulic system of modest pressure, and modest flow. Pulling back on the control is pressure to the 3 ports (one on the right, and two on the left). They are all connected internally and work at the same time. The return goes from the cylinder back through the single hose to the resevoir. It is pretty much stone reliable. The level is checked with a tall cap under the front of the gas tank on the right. If the dip stick is missing, I believe the level should be about 7" doun the pipe. (someone needs to measure a dipstick, mine it 780 miles away) When the lever is in the center of travel (latched on the small catch on the bottom of the rod) the system is on hold, keeping the cylinder up. When lifted upward and pushed forward the pressure is released and gravity (or springs return the oil, as the equipment lowers. To put on two way valves will work. It requires a open center two way spool valve, and for the regular control to be on (pulled back all the time). The valve would be connected with input from pump, output to each end ov a cylinder, and discharge back to either the drain plug in the bottom of the belly pump, or into a T fitting at the fill cap. This system's limitation is that it is not "live" it only works when the clutch is out. Many possible other ways to get live hydro are available, but on that model it should include replacement of the front cover of the engine and up graded gears and an appropriate live pump placed between the distributor and the oil fill casting. I hope this helps. Please help us help you with better keyboard effort, many "Blogs" have deteriorated to easily misinterpreted strings of letters. Ours has safety related information that must remain clear and definite, thanks, JimN
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
