Re: helical gear on top of steering post on M
Posted by DEWAYNE UTRUP on March 02, 2006 at 09:29:09 from (216.227.55.31):
In Reply to: helical gear on top of steering post on M posted by Henry Hiss on March 01, 2006 at 10:08:45:
HENRY,
The 4# sledge usually does it but perhaps you could wedge a couple large chisels or splitting wedges between the bottom of the tractor and the top of the plate the tricycle front end mounts to. Apply this extra pressure then resume hitting on top of the shaft.
good luck
