Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: spark plugs won't last
Posted by Paul Fox on January 10, 2000 at 10:27:20 from (209.222.216.2):
In Reply to: Re: Re: Re: Re: spark plugs won't last posted by wade on January 10, 2000 at 09:19:00:
Well, I guess that blows THAT theory, doesn't it? :-)
I presume you've checked all the ignition components, points, rotor, cap, etc?
Still might be informative to see if the '39 plugs that have quit will run in the '45.
Post A Followup
: Re: Re: Re: Re: Re: Re: spark plugs won't last
