Re: Year model of old M- Farmall
Posted by RustyFarmall on March 03, 2006 at 07:17:20 from (199.120.81.224):
In Reply to: Year model of old M- Farmall posted by Roy Durrett on March 03, 2006 at 07:02:27:
That serial number makes it a 1950. The X1 suffix means it came from the factory equipped to run on gasoline. What parts do you need?
Most of the parts you will need are designated as prior to a certain serial number, or after that same serial number. You will be looking for parts to fit the "after" category.
