Re: FRONT END SHAKES
Posted by Bencie on March 03, 2006 at 15:45:42 from (216.9.175.125):
In Reply to: FRONT END SHAKES posted by NEALE on March 02, 2006 at 18:28:04:
Neale, at the end of the steering column, front of gear box is a cap that threads off, there is a bearing on the end of column, if this bearing has any play at all, it will make the steering shake bad at road speed. The bearing is expensive from IH, about 80 bucks, I got one from GMC dealer for around 15$. GMC TOPKICK gas engine pilot bearing in flywheel is same size just is a sealed bearing instead of open.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
