560 help again
Posted by Big Red M 46 on March 04, 2006 at 17:06:23 from (71.124.41.222):
Okay, I posted earlier about replacing the TA in my 560 farmall. I had the flywheel resurfaced while the tractor was apart, clutch and presure plate looked good. When I got everything back together the clutch is not releasing . I can shift through the gears when not running, but cannot put in or out of gear when tractor is runnig, I puled it back apat again today and tried putting the clutch disc the other way with the same results. The clutch worked before I ever started this. I have adjusted everything in accordance with the manual.
