Re: Starting 560 D
Posted by NIndianaDan on March 05, 2006 at 17:07:37 from (4.252.70.231):
In Reply to: Starting 560 D posted by Joe Serrani on March 05, 2006 at 16:38:03:
On the bottom right hand side of the dash is where your glow plug switch should be. Things are painted white down there and your right knee will be close to it. There is a meter with the push button. Push the button for 60 sec. Throttle at 1/4. Try to start it. There is a push/pull rod in the GPlug switch area that needs to be pushed in to start and pulled out to shut'er down. Some or all of your Gplugs may not work. And,if it's cold where you are, you may need a block heater too...If so, get the kind that circulates water ..don't get the oil dip stick kind. Dealer, ebay or Bates Eq.(online) will have your manuals. Good Luck!
