Re: Farmall Cub Clutch
Posted by billde on March 05, 2006 at 20:37:01 from (66.249.53.208):
In Reply to: Farmall Cub Clutch posted by B Hackford on March 05, 2006 at 18:05:51:
Rotate the lever with the slot in it counterclockwise until you have 1 inch of pedal free travel. check to see if you have 1/8 clearance between throwout bearing and fingers with the clutch pedal to the rear.
