Re: m not getting any spark? not sure about wiring
Posted by El Toro on March 06, 2006 at 04:10:33 from (64.12.116.65):
In Reply to: m not getting any spark? not sure about wiring! posted by Booe on March 05, 2006 at 21:12:11:
Pull the coil wire from the center of the distributor cap and hold it within 1/8 to 1/4" of a good ground on the tractor frame. With the ignition switch in the on position have someone
to attempt a start by cranking the engine using the starter. You may want to use a pair of insulated pliers so you don't get bitten.
You should have a nice hot blue spark while cranking. If the spark is weak and orange your coil may be the problem. If it's blue and hot
the points, condenser, rotor and wiring may be the problem. Check your plug wires at the cap
to make sure they're in the correct firing order.
If the rotor turns CW your wires should be in this order. Make sure the points are set at .020" and are clean. Slide some 320 grit paper through them and then use a cotton swab dipped in alcohol to clean the points. Hal
2-1
4-3
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
