Re: Super H front end finally tight! Gotta do that
Posted by PeteNY on March 06, 2006 at 06:46:04 from (72.73.8.175):
In Reply to: Re: Super H front end finally tight! Gotta do that posted by Andrew Z on March 06, 2006 at 06:07:34:
Andrew, if the bolster has play it may be the bolster bushings; a big one at the bottom and a smaller one at the top. I got a whole rebuild kit from Carter and gruenwald, but the parts are available separately from CNH...I did have to shim the key way where the 2 shafts meet; bothe the key and the shaft. I was amazed how much shimming that and changind the u joint helped. Pete
