Farmall Tractors Discussion Board
Re: Re: M engine siezed up ?????'s
Posted by Rick on January 10, 2000 at 15:54:58 from (208.157.191.253):
In Reply to: Re: M engine siezed up ?????'s posted by The Red on January 10, 2000 at 13:39:01:
Ben if you drained water out of the oil pan,odds are you had water in the cylinder, if this is the case your best bet to make this tractor run good is to pull the head.If you don`t have any busted cylinder,you can cut the ridge out and hone the cylinders and grind the valves.That is if you plan on keeping this M.
Post A Followup
: Re: Re: Re: M engine siezed up ?????'s
