Re: PTOclutch gear
Posted by Bernard le mécano on March 06, 2006 at 07:20:56 from (207.134.112.15):
In Reply to: PTOclutch gear posted by Dave in Va on March 03, 2006 at 16:01:59:
Hi Dave, remove the lever assembly before, slide the collar on the rear shaft, then pull the shaft out. Be carefull to do not drop the collar when you pull the shaft. It have a bushing in the front of the shaft, check and replace with a new. Bernard le mécano Québec Canada
