Re: Hydraulics
Posted by Nat 2 on March 06, 2006 at 10:39:10 from (64.80.108.53):
In Reply to: Hydraulics posted by NSC on March 06, 2006 at 07:33:02:
You were researching LIVE hydraulics. They'd still be one-way, but they would operate with the clutch pedal pushed in.
It's not that the cam gear would break, it's that the factory live pump won't even fit on pre-1950 Ms. The front engine cover is different on the newer models.
Two-way hydraulics is a matter of plumbing and the right kind of hydraulic valve. You're looking for an open center, double-acting spool valve such as the Tractor Supply #1820128. Mount that in a convenient locaton where you can easily operate it.
Run a hose from the front pressure port of your belly pump (or the port all by itself on the one side), to the IN on the valve. Run another hose from OUT on the valve to the hydraulic filler tube under the gas tank. You can add a T for the hose, or just plumb it straight in, but keep in mind that you need to tear the system apart to add or check the fluid level if you choose to plumb it straight in.
Now, run two hoses from the work ports on the valve to the rear of the tractor. Add quick-disconnect couplers, and you're done. To operate the system, simply pull the rod for the belly pump valve back and lock it into place, then operate the control lever on the spool valve.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
